    Aug 2009
    5
    Default Insulate a 100 yr. old house
    Please tell me where to get information of how to insulate (without spending a fortune)a 100 yr. old house that has no real access to the underside of the roof, a tile over metal roof, is 3 stories high, and the outside all brick with inside all plaster. HELP! It's really cold in the winter, even with a double furnace.
    Aug 2009
    Western Kentucky
    Default Re: Insulate a 100 yr. old house
    We've got a two-story with wood siding, plaster interior. Years ago I used a hole saw from the inside, bored every stud bay and blew in cellulose for the top floor. First floor I pulled two rows of siding, but you can't do that. Lots of holes to fill, but it's a real opportunity for new wallpaper borders to cover them up!
    What do you mean, "no access to the underside of the roof"? You don't have an attic with access? You don't want the insulation directly on the roof, you need it on the attic floor/top floor's ceiling.
    May 2009
    Elyria, Oh.
    246
    There should be an access area to the attic. Most of them are in a closet. Look in each closet for a hatch to the attic. We own a five story apt building and I had to create two hatchs by sawing out a hatch between two joists. I then by using trim and a piece of plywood created a hatch to the attic to insulate this building. I put one hatch in each one of the four apartments and then using a machine blew ground up newspapers into the attic
    for insulation. This is a DIY thing but you can hire a pro.
