Thread: Door threshold
    Sep 2007
    Default Door threshold
    We had to replace several beams under the house and had to remove the front stoop. The old beams where notched for the threshold. How do I replace the threshold, without notching the beams????
    Chicago, IL
    162
    Default Re: Door threshold
    I believe it's one of Newton's Laws that states that 2 objects cannot occupy the same space at the same time.
    Either notch the beams or notch the threshold.
    HTH
    Dave
    1,906
    Without a picture or better description, I doubt if anyone can help. What's the problem with notching a beam a little for the threshold?
    5,942
    You might be able to raise the header, and the door opening. Pictures would help.
