Results 1 to 1 of 1
    Jun 2009
    Default Sink and P-trap lining up
    I recently installed a new sink/vanity - and wouldn't you know it the stupid P-trap doesn't line with the Ameraican Standard "quick connect" drain. -
    I dont know much about plumbing but I can follow directions -
    I think my best bet is to cut the pipe coming out of the wall, leave it sticking out about 3inches and somehow attach a PVC pipe/p-trap?
    The metal tail piece that appears to go through that round O ring to hide the hole in the wall is connected into a copper pipe, just on the other side of that ring. So if I were to cut the metal tail at that copper pipe, whats the best way to then assemble a new PVC tail-pipe/p-trap and have to connect into that copper pipe that IS NOT threaded?
