Results 1 to 10 of 13
    Oct 2007
    36
    Default Need advice about shoplights in basement
    Hello Everyone,
    I am having problems with my basement lighting. How many shoplights per on/off switch is acceptable?
    Here's the history of my lighting problem. Sorry if it's so long:
    In 1976 we had shoplights installed in our basement. Two in the laundryroom, one in a storage room/office. Each room has their own switch.
    The main area of the basement has four shoplights (set of two in each fixture). I'm not sure of the watts. Originally, these were controlled by a dimmer switch. However ten or more years later, the lights began to flicker. At which time an electrician told us that dimmer switches are not the best to have and replaced that switch with a regular, nondimmer, switch. The lights worked fine until 2004. At this time, another electrician said that the switch was lose and needed to be tightened. The lights worked fine until 2009.
    Gradually each light dimmed or would not work at all. This led me to believe that they needed to be replaced. I purchased some new replacement lights -- and when we went to install them -- lo and behold -- all of the lights worked. The guy who was helping me said that I may have problems with the ballusts (sp?).
    A week later, the lights were acted up again. Some light while others didn't. Some of those that weren't working, came kicked on later.
    I've talked to various people what could be wrong -- and still have to find an electrician that can squeeze me into his schedule. All have stated that it could be the ballusts, in which case new fixtures would be more affordable than just replacing individual ballusts; it could be the shoplights themselve, or it could be that there are too many lights for the one switch to handle. (Again there are four, with two lights (48-inch) in each. There is one switch at the bottom of the stairs and another at the top. (The one at the top also houses a switch to the garage; and the switch at the bottom houses the switch to main basement lights that are acting up and one that controls the shoplights in laundryroom next to the main area.
    One person suggested that the air in the basement may be too damp at times, and when the humidity/dampness decreases, it causes the lights to work properly. There are registers to the basement, but we don't allow the basement to be heated. I run the dehumidifier 24/7. During the summer it has to be emptied three or more times a week (bin is half full). During the winter, I hardly ever have to empty the dehumidifier.
    Any opinions or suggestions will be appreciated!
    Apr 2008
    74
    Default Re: Need advice about shoplights in basement
    If the lights were installed in 1976 and you haven't had to replace them or the ballusts yet, odds are it's time. You have more than got your money out of them.
    I would suggest you go to a home center near you and purchase the modern day equivalent / replacement and either install/replace them yourself or have an electrician do it for you. They are fairly easy to replace.
    As far as the switches being "overloaded". . . I highly doubt it. Four shop lights as described should not be an issue.
    Good luck and way to go keeping those originals running for 33 years!
    Tim
    wisconsin
    159
    tim was right. 4 flourescnet lighs should only draw somewhere around an amp or two apiece. so you are well below what your switch can handle. id go to your local box store and buy 4 new ones for 20 bucks a piece or so and replace em yourself.. cost you 1/4 of hiring an electrician to come in and diagnose the problem, then telling you most likely to replace them anyway..
    Shamokin, Pa.
    645
    I agree with those two follow up replies. Are you thinking about using T12s, vastly outdated, or going with more efficient, but also more costly, T8s?
    1,898
    Unlikely that the switch is the problem, but considering the age of it you might want to replace it anyway. They can suffer wear over time. They aren't expensive to replace. I'd suggest getting a "spec grade" or "pro grade" switch, as they will last longer.
    How cold is it in your basement? Some older fluorescent ballasts have trouble starting below 50F. Newer ones are generally good down to around 35F, and you can get "cold start" ballasts that are good down to 0F.
    Oct 2007
    36
    Thanks for all your advice!
    I had a friend look at the lighting to see how easy it would be to replace/install them. He has more experience in that area than I do and suggested new ballusters/fixtures that have drop down covers. Currently, I have the old sliding covers that fit in the ceiling tile dividers.
    He said that new fixtures/ballusters would cost around $50 each, are more energy efficient, and would include the entire "kit."This includes the drop down covers. Is this what you guys are talking about?
    By the way, my basement is usually 10 to 20 degrees colder than the main floor. However, it may be less, since I recently had insulation installed around the perimeter of the basement.
    Thanks again!!
    Shamokin, Pa.
    645
    Quote Originally Posted by Toody View Post
    Thanks again!!
    A T8 ballast kit to replace the present T12 could be what he is talking about. I personally use the more efficient T8s when ever practical, as those new unit will be in use for a long time.
    Oct 2007
    36
    Thanks, Ernie! Do the T8 kits cost around $50 as my friend thought? Also, did you say that the T8s were long lasting?
    1,898
    The T8 lamps with electronic ballasts have many advantages over T12 and the old magnetic ballasts:
    • * More energy efficient
    • * More light output
    • * Reduced flicker
    When you go shopping for fluorescent tubes, you'll find a bewildering array of them. Some are brighter, some are dimmer, and they produce different colors of light from reddish (warm white) to bluish (cool white), represented by a "K" number referred to as a "color temperature". I find 4100K lamps to be the most pleasing; this is what is most commonly used in schools and office buildings around here.
    Oct 2007
    36
    Thanks. There are so many options out there!
