    Apr 2009
    Default Inspector said to ground 2 outlets--can I just add GFCI and add sticker?
    I can't afford to rewire the whole house -- can I just add a GFCI outlet and put a "not grounded" sticker on it? I'm in North Texas if that matters.
    Maryland
    1,910
    Default Re: Inspector said to ground 2 outlets--can I just add GFCI and add sticker?
    Not an electrician, but to ground 2 outlets, the whole house doesn't need to be rewired.
    GFI outlets must be grounded.
    A building inspector or a house inspector hired when buying a house.
    5,942
    First, a GFI does not have to be grounded.
    Second,Why did the inspector say that two outlets need to be grounded? Are all the rest grounded, if so you may just have a loose connection on the two, if not there is no code requirement, that I know of, to ground ungrounded outlets.
    Midwest
    179
    I agree, maybe they were grounding type receptacles, which must be properly grounded unless they are GFI's. Also the sticker has no effect on their operation or legality.
