Thread: slippery tiles
    Sep 2008
    8
    Default slippery tiles
    Our floor tiles get very slippery when they are wet. Is there anything that I can use to make them unslippery ?
    TIA,
    Pat
    Dec 2008
    Default Re: slippery tiles
    First of all, you need to make sure you are cleaning your ceramic tile frequently and properly, or it can significantly contribute to the ceramic tile being too slippery. Use the tile cleaning solution and scrub the floor with a brush on an extended handle. Then use a wet and dry vacuum to pick up all the dirty water.
    Sprinkle baking soda on it and let stand for a few hour and sweep up and mop it should absorb any thing slick on floor. The more texture, the easier it gets dirty, the more frequent you have to clean it and the more difficult it is to clean. Good Luck!
    Sep 2008
    8
    Thanks. I'll try what you said. The tile really doesn't have too much texture. It is very shiney.
    Thanks again
    Aug 2009
    Check out www.slip-doctors.com or www.slipdoctors.com for an ati-slip product for your bathroom, tiles, bathtub, pool deck, etc
    SlipDoctors makes your bath non slip.
    Stone-Grip makes your floor non slip.
    Your floor will be non slip for life.
    Our non slip treads are a permanent solution.
    We can make your bathtub non slip.
    You can own non skid flooring.
    You can have a non skid surface.
    You can own a non skid tub.
    Non slip floor tiles are important.
