    Aug 2009
    Default nailing requirements for romex within 8" of box
    Wiring wall receptacles in new detached garage. Framing is 2X6 on 24" centers. Code calls for stapling romex within 8" of box. However, boxes are 6" above hole in stud. Do I still have to staple the wire. Also, how much slack do I need to leave outside the box and will this affect the staple requirment.
    THX
    1,890
    Default Re: nailing requirements for romex within 8" of box
    AFAIK, no slack outside the box is necessary, and staples are cheaper than the annoyance of having the inspector make you correct that issue, especially if you didn't leave enough slack to staple the wires.
    8,002
    Staples should be placed within 6" of the box, regardless of where the hole in the stud is. The next rule of thumb is you want 6" of wire to penetrate through the box, that's at the point of penetration, not the face of the box.
    1,890
    You should leave enough wire sticking out of the face of the box to easily make connections and future repairs. However, too much wire will be tough to stuff back into the box along with the device it's connected to.
    May 2009
    21
    I always staple my wires before entering a switch or outlet box. I leave 5-6 inches of slack wire from the face of the box after i have done my make-up. The idea is that the next person in that box(me?) can pull the device out and inspect and or repair the wiring with out disturbing the wires in the walls.
