Thread: Moentrol Stuck
    Jul 2009
    Default Moentrol Stuck
    I have a Moen faucet in my shower that had a Moentrol. I requires a slotted screwdriver to remove it. It's stuck. Does anyone have an idea besides shocking it with a punch or using WD40 (I've tried these) to remove the stuck Moentrol?
    Thanks,
    Steve
    Jan 2009
    Taxachusetts
    136
    Default Re: Moentrol Stuck
    I actually believe that moen sells a tool for the purpose. It works similar to a handle puller and costs about $15. If that's too expensive for a one time use just be careful not to damage the brass/bronze body of the valve itself. There is also a c-clip that needs to be pulled first.
    Shaun
    Jul 2009
    Thanks Shaun but I think you are referring to the faucet cartridge, not the Moentrol valve that is another part of the faucet. I did successfully use a puller for the faucet cartridge (I (needed to).
    The Moentrol valve is to the right of the cartridge and has a slotted head for which a wide screwdriver needs to be used (not a "handle puller"). The Moentrol the "flow control" valve of the faucet.
    Thanks for responding.
    Steve
    Jul 2009
    Talking FIXED - Re: Moentrol Stuck
    I solved my problem.
    I bought an impact driver that I could hit with a hammer. When I hit the impact driver while in the screwdriver slot of the balancing spool (I erroneously called it a flow control), it would "jar" and "unscrew the balancing spool a tiny bit. That freed it after 3-4 taps with the hammer.
    I also bought - but did not have to use - a can of some kind of gas that would "freeze" the end of the balancing spool. My theory is that it would shrink the threads and loosen them. I saved the can for my next adventure.
    By the way, Moen said to replace the #1423 balancing spool if it did not rattle when you shook it. Mine did not rattle. I took it apart, removed the calcium build up with sandpaper, picks, and a little soaking in vinegar and saved a few bucks. The faucet now successfully provides both cold and hot water at normal pressure.
    Thanks,
    Steve
