Results 1 to 7 of 7
    Jul 2009
    Default rusted bolts on tank
    Have a tank bolted on with round heads that require flat head screw driver to remove. The nuts and bolts are rusted together and turning only strips the bolt heads. Any ideas on best way to remove these?
    Apr 2008
    74
    Default Re: rusted bolts on tank
    Go to the hardware store and buy some Liquid Wrench. Put it on liberally and wait for a few minutes. Should loosen the bolts enough to unscrew. If not, give them another dose and wait several hours and try again.
    If this doesn't work, go to the HD or other hardware store and buy a damaged screw removal tool (can't remember the specific name). Basically it is a set of bits that will re-tap the screw head and another bit that fits this re-tap that allows you to take the bolts out.
    Good luck! Tim
    8,065
    Fastest and easiest way is to cut them off. Use a keyhole saw or hacksaw blade with tape wrapped around one end to make a handle, then cut through the rubber washer inside the tank. If you can access the bottom of the toilet flange more easily, you can cut the bolts there. You could probably use a rotary tool with a burring bit to remove the head as well. Wear safety gear.
    2,009
    If the bolts are real rusted sometimes they can easily be broken off with a pair of vise-grips by rocking the bolt/nut end back and forth.
    If you try liquid wrench, let it set for a day or more. keep reapplying. Heat with a torch to break the bond between the nut & bolt. Be careful the LW may be flammable.
    I've also cut an additional slot in the head with a hack saw when the original slot got too chewed up. Use a large screwdriver that fills the slot.
    It all depends on the situation.
    Apr 2008
    74
    Good calls, guys! It must have been early -- I wasn't even thinking toilet tank! Not sure LW would be the preferred method here!
    Good luck. Tim
    2,009
    Quote Originally Posted by TRLambert View Post
    Me neither. I was thinking some big old steel tank.
    8,065
    LOL That's funny! You guys were reading a storage tank of some kind and I was reading toilet tank. I went back to the OP's post and there really isn't any way to determine what he was talking about. My guess, by the description of flat head screws that it's a toilet tank, but your guess is as good as mine!
