    Jul 2009
    mich
    Unhappy clogg bathroom sink
    I have tried everything to open my drain remove trap under sink i have used all sorts of drain opener no luck no other drain in the house is plug up the water will not go through its just sit even after plungeing over and over please help thank you blueskys818
    7,586
    Default Re: clogg bathroom sink
    Sounds like it needs to be snaked to clear it. You could try a pressure blasting nozzle. It's a bladder that fits the end of a garden hose. You insert it into the drain and it automatically expands to fill the pipe, then it will pressurize the pipe and 9 times out of 10 push the clog down into the larger waste main where it will flush itself out. You can find these on the plumbing aisle of most hardware stores.
