Thread: Septic Systems
    Jul 2009
    Default Septic Systems
    I am looking for a septic system that I saw somewhere sometime ago. I tought it was on TOH.
    This system used a plant bed to treat the waste water because the plants absorbed the waste material. The result of this process was crystal clear water which could be reclaimed to water the landscape.
    In my mind it was called Ever Clear or Ever Green, I just don't know.
    I would appreciate any help.
    5,836
    Default Re: Septic Systems
    The first thing to do is find out if it is legal in your jurisdiction, second would be to determine is you have sufficient area for the wetland required for the load.
