Results 1 to 8 of 8
    Jul 2009
    Default Painting Driveway
    Hi
    I have an old driveway discolored etc.
    Had a new driveway put in 8 years ago and it is a different color, different finish so I don't think stain would work.
    I am looking at painting with 1 part epoxy from Behr.
    Any advise or reviews would be appreciated
    Eden, NC
    285
    Wink Re: Painting Driveway
    Painted concrete becomes slippery when wet. I would check into an industrial cleaner and high pressure washer for the old concrete and then try a sealer to bring both concretes closer in color.
    Calcats
    Aug 2009
    5
    Default Re: Painting Driveway
    Painting concrete will never last very long because of moisture. You need to seal the concrete to keep moisture from causing paint of epoxy from peeling off. What part of the country do you live in.
    Oct 2009
    KS
    19
    I would not coat the driveway with the epoxy you spoke of. Look into concrete stains if you want to color the driveway.
    Other posts are good advice.
    Россия
    5
    I really want to do this to my stock 94 accord EX wheels, but I dont wanna pay for a professional powdercoating job. Any one have a DIY on this? What kind of paint, clear coat, primer etc...
    Also when painting them, do you have to take off the wheels from the rubber and after paint remount them? Or can you just tape off the tires? Any help would be appreciated
    7,152
    Quote Originally Posted by SvetaCemament View Post
    Your best bet is to powder coat the rims, merely applying paint to the surface won't hold up to the abuse of having new tires put on, the installation of wheel balancing weights, etc. Bare rims will be the easiest to work with.
    Mar 2010
    27
    Pressure washing with a high power pressure washer works for most paints with exception to some of the stronger paints such as epoxies. Of course, this method is only recommended on exterior surfaces.
    Shotblasting will strip concrete of most coatings as well as the surface of the concrete itself. If you don't want to alter or damage the concrete surface then don't use a shotblaster. This machine is like a sandblaster, but shoots tiny metal beads which can easily be recollected as you go. A vacuum is attached to the machine to suck up the dust and debris. A shotblaster will also create a nice profile for any future coatings or toppings. But you must be careful and move along at a steady pace or you will strip too much of the concrete itself. The problem is these machines are hard to find and expensive to rent.
    Jan 2015
    28
    Like John mentioned. Staining is probably best. Shotblast or acid etch the surface. Get a suitable concrete stain, I like tru tints, and apply with a simple garden sprayer. Water based concrete stains are easy to dilute to modify the color to your liking. Once complete, use a good sealer. Look for a non slip type sealer such as heal and seal deco or use a non slip additive if you find a sealer at a local concrete supply store.
