    Sep 2007
    Default window counter balance replacement
    i have an older home the windows are counter balance with Pocket weights. I ma rebuilding the windows and I want to insulate the pockets. I have seen a product that replaces the weights and pulleys with a spring loaded sash lift. The mechanism fits into the slot where the pulley is located. A flat strap replaces the cord and a spring( a larger watch maker type???) replaces the counter balance weight.
    Any idea where to obtain???
    Thanks
    5,942
    Default Re: window counter balance replacement
