Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    5,940
    Default Re: Old toilet flange bolts
    Old Tom,
    In the link that I posted they mention a repair strap that you can pick up at most hardware and big box stores. I f bolt breaks off cut out a section of the flange and use one of those straps to hold the new bolt and slip it under the remaining flange.
  2. #12
    Jul 2009
    19
    Thanks, I just picked up a couple of those yesterday to keep handy.
    Tom
  3. #13
    Sep 2007
    8
    How old are the bolts? If the bolts are too long, you can use a reciprocating saw or a hacksaw to cut off the excess.If they are not long enough it might behoove you to use marine plywood under the toilet for stabilization and install the right size.
  4. #14
    Aug 2009
    Arizona
    5
    Ive dealt with this issue quite often. whenever i come across an old bolt setup i install a quick set flange the slides into the 4" cast pipe expand the set screws anchor it to the concrete and problem solved you now have a new flange to secure your toilet to. this can also be used when you come across broken cast flanges
  5. #15
    Jul 2009
    19
    Thanks, I try to keep a supply of just in case parts with me for such jobs, so I'll look for one to add to my collection.
