    Jul 2009
    Default Heat duct insulation
    I have forced air heating and would like to insulate the duct work in the unheated crawl space under the house. Found some duct wrap (R3) but would like something more. Would it be feasible to wrap the ducts with R 13 fiberglass and then wrap that with plastic or foil for moisture barrier? Looking for someway to instulate them economicaly but effiently!
    Jul 2009
    Northeast
    661
    Default Re: Heat duct insulation
    If I were you I'd use the right Insulation, if you can't get it at an HVAC Supply House try Home Depot or Lowes, don't forget the foil tape. Do it right, Do it once Good Luck!!!
