Thread: Drippy Faucets
    13
    Default Drippy Faucets
    Over the last 3 years, I had several faucets and showers start dripping. I made it a point to go through the house and change out the rubber washers in them, which at the time stopped the dripping. I figured this would solve the problem for a few years. This spring (April) I installed a water softener (no water softener previously - had hard water) and it's working great. However several of my faucets have started dripping again. Could this be caused by the conversion from hard water to soft water?
    Jan 2009
    Taxachusetts
    136
    Default Re: Drippy Faucets
    The more likely culprit is high water pressure. Buy a water pressure gauge that attaches to your outside faucet or washing machine connection (it's called hose thread or garden hose thread) and see what you get. Anything over 80 pounds is to high and would require the installation of a pressure-reducing valve.
    Shaun
    13
    Thank you very much for the tip...Wife is on the way to lowes now to buy the gauge.
    6,114
    Actually the water softener in line would lower the pressure slightly. The hard water, perhaps acidic, may have deteriorated the rubber washers or mineral deposits on the seat may have made them rough causing excessive wear. I would recommend removing and cleaning or preferably replacing the seats and washer.
