Thread: wood drawers
    Jul 2009
    Default wood drawers
    How do I make all wood drawers (in old wood cabinet) slide in and out easily?
    1,387
    Default Re: wood drawers
    If the drawers are painted remove the built up paint. depending on how the drawers were made can replace the slides etc....
    Jul 2009
    There are no slides, it is wood on wood. I will be removing the old paint and repainting. any other ideas?
    7,969
    Install nylon guides to the back edge of the drawer and the front bottom edge of the opening.
    You're looking for the "L" shaped pieces like in the upper right corner of this image.
    Eden, NC
    285
    Wink Re: wood drawers
    Another solution is a product called "Slipit". You can get it at Rockler.com, woodcraft.com and Mcfeelys.com. It is great for just about anything you want to slide.
    Calcats
    Jul 2009
    19
    If you have a block of paraffin wax try rubbing the drawer bottom and the inside surface it slides on with it. I've had good luck with that.
    6,015
    If you don't have a block of paraffin you can rub an old candle or even bar soap on the slide areas as a lubricant.
