Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Jun 2009
    7
    Default Re: low voltage in bathroom exhaust fan
    Here is a diagram of the problem switch.
    When I remove the wire nuts at the broken fan fixture, I can measure a current at about 25 volts from black to white. On a whim, I reset the volt meter to AC1000 v, AC250v, AC50v and on each of these setting, the needle moves the same distance.
    Across the GFCI, it measures 140 v, across the working light switch it measures 140 v, across the switch to the fan is measures 25V, but it is the needle deflection as described above.
    [IMG][/IMG]
  2. #12
    Jun 2009
    7
    I also checked the black to ground at all points in the circuit and each measures 140v.
    I did replace the switch, but alas I have the same problem.
    I visually inspected the wiring and it is intact for the parts that I can see.
  3. #13
    Jun 2009
    7
    any further comments?
  4. #14
    6,115
    First question, on the switch is there a jumper between the top and bottom switch on the hot side?
    Second, are you connected to the common on the GFI common screw or on the load screw?
    Third, where is the common for the fan usually connected.?
