Thread: Tub Overflow
    Jun 2009
    Default Tub Overflow
    I have a tub that is about 30 years old. I took the overflow cover off yesterday and found the gasket was destroyed and the hole has started to rust away. Is there a product I can buy to correct this problem?? I don't know if there is a oversized gasket and seal to correct this problem.
    Default Re: Tub Overflow
    The gasket is replaceable, if you can't find the same size, then you can purchase gasket material and cut your own. As far as the rust goes, unless it's significant, don't worry about it. If it is significant, the only way to remediate it is to remove the rust and repaint or enamel the hole to minimize the rust from returning.
    When you replace the gasket, wire brush as much of the rust off as you can, then reassemble the overflow.
