Results 1 to 10 of 19
Thread: Moles
    69
    Default Moles
    Okay, our yard is the ONLY yard in the ENTIRE neighborhood with moles. We have been battling them since 1990. They are still winning. We have tried: spring-type mole traps, several different mole poisons, grubex to get rid of their food source, castor oil, moth balls, in ground sonic wave thingies (yes, I'm a girl), whirly gigs, and several suggested home remedies. We have even tried using all of the above at the same time. We still have moles. Short of hiring an exterminator, any suggestions?
    Thanks!
    Apr 2008
    74
    Default Re: Moles
    C4, dynamite, deisel and nitrogen mix!
    There must be a food source for them that you just aren't getting rid of through the efforts you've tried. Do you have problems with Japanese beetles? If so, their larva are in your yard.
    Try to identify the pests you have in sufficient numbers that would cause larva in your yard. Once identified, get in touch with your local county extension agent and see if they have any advice.
    Other than that, you could pen up a pig and let it tear your yard up digging for the little buggers. That might scare them off!
    Good luck. . . .Tim
    69
    Default Re: Moles
    We've seriously thought about the combination (or variances thereof) that you first suggested!! Figured the neighbors wouldn't appreciate it though.
    No japanese beetles. Only grubs and earth worms. The pig might be an option, but I'm trying to NOT have a torn up yard!
    Thanks for the response and have a great day!
    Jul 2009
    Smile Re: Moles
    I have had a similar problem, if only for the past 2 years. I recently discoverd a poison called "worms". I found them at local big box store (HD or Lowes). I also discovered that they WORK! Read the instructions, handle with care, and only use about 1/2 worm in each hole. 1 worm, half my flowerbeds are now clear, hmmmm Just one guy did all that mess? Any way I found these guys to work.
    good luck
    reco
    69
    Default Re: Moles
    Thanks for the reply. We've tried the worms too. We decided they used them for the snack at happy hour! These guys seem to be immune to every type of poison/remedy on the market, and a few that aren't on the market. Thanks again!
    Jul 2009
    Lightbulb Re: Moles
    I recently had a neighbor tell me to use wriglys gum.just to put in their trails and it they eat it and will kill them.This came from a pest control man.Give it a try what can it hurt.
    Aug 2009
    Default Re: Moles
    call bill murray,he's an expert man!!!!!!
    good luck with your moles......
    Jun 2008
    Central Wisconsin
    12
    Default Re: Moles
    What flavor of Wrigleys gum? Do you chew it up some first, or just stick in the the hole?
    Sep 2009
    Default Re: Moles
    I wish I could tell you I had a good reliable solution, but I don't. I will tell you the mole I had in my yard proved to be an excercise in frustration. I was actually talking with my father about the problem when we noticed the earth moving. I was able to take the spring trap I had bought and stab into the dirt and get the mole. I know it isn't how it was intended to be used, but in the end, $14 well spent. I guess the lesson learned is keep your eyes open, maybe you will get lucky.
    5,805
    Default Re: Moles
    I use a 22 Magnum. It usually doesn't take long to figure out when they are digging. The magnum seems to work even if you don't get a direct hit, it stuns them so you can dig them out and execute them
