Thread: A/c drain
    Jun 2009
    college station texas
    Cool A/c drain
    I had a new unit installed in the attic last year and ever since i noticed the a/c drain trickles water out. so i tried to fix the problem by replacing some sections of pvc still the same issue. i also thought that maybe the unit was not tilted? hell dont get me lying I have no idea.
    7,081
    Default Re: A/c drain
    If your AC is working properly it SHOULD drip out the condensate tube. If it didn't then you'd get water inside the house because it couldn't expel it to the exterior.
