    Jun 2009
    Default hanging cabinets in 1927 walls
    Our house is mostly plaster board over redwood planks. For the most part, these planks are not fixed to the studs, except at the floor and ceiling. When they are fixed to the studs, it's usually via another board fixed crossways to the redwood planks and studs.
    So, the question is: how to fix hanging cabinets to the wall when you can't find the studs?
    Knocking doesn't find the studs. Stud finders don't work. A finish nail through the plaster, backing and planks doesn't work (already nailing into a 3/4" plank behind the plasterboard). I have pulled a strip of plasterboard off the reveal the planks, but this still doesn't help find the studs; the nails holding up the plasterboard seem to be randomly spaced!
    Jun 2009
    Default Re: hanging cabinets in 1927 walls
    Didn't get any answers in this forum, but a contractor friend suggested the planks would support the weight themselves. It did, just fine. 2&1/2" deck screws worked fine... probably could've been longer, like 3&1/2".
    Jun 2009
    Derry, NH
    61
    Seems reasonable but I would stay away from using screws longer than needed due to the chance of hitting wiring behind the walls.
    Aug 2009
    30
    I've actually hit things in the wall with too long a screw, but it was a Apex water pipe
    2009 kitchen remodel warrior
    asbolute black granite
    Antique White Hidden Content
    Travertine 18" x 18" floor tiles.
    It looks Great!!
