    Jun 2009
    Exclamation Paint thinner and polyurethane
    Is it safe to mix paint thinner with polyurethane for wood floors? I have heard it can act as an accelerant in a fire, is this true? What are the benefits of thinning rather than straight poly?
    7,078
    Default Re: Paint thinner and polyurethane
    If you're worried about fire, there are far more flammable items in your home than the finish you put on your wood floor. Carpet, d****s, fabrics, plastics, and foams are what fuel a fire the most.
    Poly is thinned to make it more workable, have a longer open time, and to allow it to be absorbed by the wood more readily. Always follow the product instructions for thinning and application.
