    Jun 2009
    Default Sweating Garage Floor
    We just purchased a house about a month ago, it was built last fall and finished early this spring. With the recent high humidity we have had, I have found that our garage floor sweats. There are beads of sweat all over the floor and in the corners, there are puddles forming.
    Sand Springs, OK
    467
    Default Re: Sweating Garage Floor
    that's probably humidity collecting on the garage floor. It's cooler down there. My walk ways get this way but my garage doesn't get that humid.
    Debby in Oklahoma
    Jun 2009
    I was wondering if someone else had this problem and if they did, what did they do to get rid of it.
    Sand Springs, OK
    467
    Air it our really well on the driest days possible then make your garage as tight as possible so moisture can't get in there.
    If the moisture doesn't go away then maybe you could add a molded plastic garage flooring product to cover the moisture so you can't see it.
    Debby in Oklahoma
