Thread: recaulking tub
    20
    Default recaulking tub
    after i remove old caulking, i`d like to apply something like a fungicide just for peace of mind before i apply new caulking. is there anything suggestions? thank you
    8,065
    Default Re: recaulking tub
    The joint needs to be thoroughly dry before recaulking with anything, or your efforts will be all for not. You can wipe the joint down with a bleach solution prior to caulking to kill mildew that would otherwise be trapped by the caulk.
    IMHO, it is wisest to use a tub and tile latex caulk because the caulking will fail eventually and latex can be removed. Silicone leaves a "greasy" film that no other caulking, including silicone will stick to, and it's also much harder to work with than latex.
