    Jun 2009
    Default Faucet Seat Retainer Bowl
    Does anyone know where to obtain faucet seat retainer bowls?
    When the rim of the faucet seat is in bad shape, you can file the seat flat and install a retainer bowl. The washer will then sit in the retainer bowl, which has become the seat.
    If this is confusing here are a couple of photos from "Ask This Old House":
    http://www.thisoldhouse.com/toh/how-...132282,00.html[/COLOR]
    and
    http://www.thisoldhouse.com/toh/how-...132284,00.html
    Thanks in advance.
    West Jordan, Utah
    84
    Default Re: Faucet Seat Retainer Bowl
    You should be able to buy faucet retainer washers at a plumbing supply house or hardware store. They can also be found on line if you search for faucet washer retainer.
    Slow The Flow
    Jun 2009
    Blake,
    Thanks much, I found it ******.
    I searched using all of the variations I could thank of to no avail.
    Using your suggestion I found 'em.
    Thanks again.
