Poll: How can wooden window sills on a screened porch be protected from the weather?
Be advised that this is a public poll: other users can see the choice(s) you selected.
    Jun 2009
    Pennsville, NJ
    Question Rotting window sills in screened porch
    The window sills in my screened porch are beginning to rot. The porch is four years old. Originally, the sills were covered with tile to protect them from the weather. The weight of the tiles and the mortor cracked and heaved the first winter. Last spring, I had the tile removed and the sills rebuilt. The sills were stained and coated with polyurethane. I coat with polyurethane each spring. The sills are beginning to split and rot . What can I do to prevent them from getting any worse?
    Jun 2009
    Smile Re: Rotting window sills in screened porch
    What about covering with vinyl or aluminum siding and using caulk.
    Jun 2009
    Pennsville, NJ
    Default Re: Rotting window sills in screened porch
    Good idea, by the sills are on the inside of the porch. I don't see how I could cover them.
