    Jun 2009
    Default Cutting in wall/ceiling
    Is there an easy way to do this from the floor (8 ft), with a telescopic handle and something?
    From dizzy on the ladder.
    7,084
    Default Re: Cutting in wall/ceiling
    Yes, hire a painter and say, "go paint that". This technique also works well when sitting in an easy chair. Seriously, you might be able to use an extension wand, but getting the hang of using it might not be worth the expense or effort. You'll want a wand that is made for holding a brush, taping the brush to a stick just doesn't offer the stability needed to do a good job.
