Thread: Smelly Bathroom
    Jun 2009
    Default Smelly Bathroom
    We have a master bathroom that has just been remodeled. Before the remodel no smells, after we tiled the bathroom we noticed a musty, gassy kind of smell. Plumber has checked everything and says everything is ok.
    Could it be the new tile and grout smelling?
    What could it be???
    Feb 2009
    693
    Default Re: Smelly Bathroom
    For me it is rotting hair in the drains....... I mean, your own fresh pee may smell great to you.... But rotting hair? Oh, My! Whew!
    Jun 2009
    Everything is brand new in this bathroom - it has only been used a handful of times so if we are sheding that much hair then we have other issues....
    7,970
    You might try plugging off the shower and/or tub drains tightly for a bit and see if it dissipates. If it does, then I suspect that you have a drain problem such as no trap or leaking trap which is letting sewer gases into the house. What kind of floor covering?
    Jun 2009
    flooring is tile...will try plugging everything up...
