    Jun 2009
    florida
    Default can you retrofit a Square D load center
    I may have to upgade from 200amp to 225 amp. service. My question is... Does Square D make a retrofit assembly that makes it possible to just change out the buss assembly and main breaker and supply stickers to reflect the change. Instead of pulling out all the wiring, changing the box, pulling the wires back in etc. etc.
    6,024
    Default Re: can you retrofit a Square D load center
    Why do you have to upgrade from 200 to 225 amp?
    And generally speaking upgrading a load center usually costs more than a new load center.
    Feb 2009
    693
    200 to 225? Gotta ask why you have made that decision.
