Results 1 to 1 of 1
    Feb 2009
    Default Restoring a rock floor
    I have closed in a 12’ X 16’ patio that has a 40 year old floor made up of large pieces of TN. Flagstone set in concrete. The floor is still in pretty good shape, with only one very narrow crack coursing through the rock pattern. Edges of the rock , in random areas , extend as much as 1/8” above the concrete joints. The floor currently has a fall of aprox. 1 “’s over 12’, sloping away from the house foundation , so any attempt at leveling with a clear coat material would probably be excessively expensive. What I want to do is improve the flatness of the floor with a clear coat that would also provide a durable glossy seal over the top of the rock . Does anyone have any suggestions on how to accomplish this, and what type of resin to use. I have considered the necessity to do it in multiple coats, working aprox. a 9 square ft. area at a time for the first coat, and following through with a complete covering on the final coat. Again, I am not necessarily trying to get it totally flat, but a significant improvement would be acceptable. I also believe that trying to achieve too heavy a pour on the first coat would result in the coating material attempting to self level, and thus flow excessively down hill. I have investigated one and two part epoxies, polyurethane, molding plastic, etc. etc. Just not sure about anything. See attached photos. Please help !!
    Thanks in advance ,
    Dave
Name:	rock floor 003.jpg
ID:	2517   Click image for larger version.
Name:	rock floor 002.jpg
