    Sep 2015
    Default Blued Wood Screws
    Hello all,
    A quick question. I have boxes of old round head blued wood screws and I was wondering what they are/were used for. They came from my grandfathers wood shop and I found them while cleaning out a storage unit. I can't find any info on the web and thought I would try here.
    Thanks,
    Mark
    1,890
    Default Re: Blued Wood Screws
    Pretty much anybody's guess would be valid. I've seen them used for assembling wooden items where disassembly may be required; a visually attractive screw is desired since it's exposed to view. For example, my parents had an old pump organ; the front panel just under the keys was removable for servicing the mechanism. The panel was attached with two round-headed, blued wood screws.
    Being blued, it could be used with stained materials and not be visually obtrusive, as a bright, zinc-plated screw (like you get at the hardware store nowadays) would be. Bluing was an early method of rust prevention, prior to the invention of galvanizing, anodizing, or powder coating.
    7,762
    "Being blued, it could be used with stained materials and not be visually obtrusive, as a bright, zinc-plated screw (like you get at the hardware store nowadays) would be. Bluing was an early method of rust prevention, prior to the invention of galvanizing, anodizing, or powder coating"
    This is probably true.
    Today we use blue screws for outdoor applications, but really, these exterior screws come in different colors.
    You can use these screws for various jobs, or save them as "grandpa's gift".
    1,890
    Lest anybody be confused, bluing is not the same as the blue outdoor screws!
    https://en.wikipedia.org/wiki/Bluing_%28steel%29
    Dec 2013
    Montreal Canada
    333
    I remember an old carpenter saying that he held blued nails in his mouth and that the blued one tasted better. this was the way 40 years ago
