    May 2009
    Default Girggling toilet
    I have a toilet in my hall bath that girggls,looses water.If you flush the toilet in the master bath if well back up,and not overflow but water comes out from under the base of the toilet.
    You can hear the toilet(s) girggling & you can hear the vent in the hall for the hvac,that is attached the drane. Could I have a stopped up vent??
    Jan 2009
    Default Re: Girggling toilet
    Maybe, but I'd check the drain line that the toilet that almost flows over first, then snake the main line that both are connected to second.
