Results 1 to 9 of 9
Thread: How
    May 2009
    Default How
    I want to install a dishwasher and there isn't one there now how do I do the electric ?????
    1,907
    Default Re: How
    I think that dishwashers are required by code to be on their own, dedicated electrical circuit, usually 120V 20A, wired with 12 gauge wire (12/2 W/Ground).
    An alternative that may not meet code but would probably work is if you have an outlet under your sink for a garbage disposer, you could wire your dishwasher with a cord and plug and plug it in there.
    6,103
    Default Re: How
    Quote Originally Posted by vw3cs View Post
    With no more information than you supplied and not knowing your electrical experience, I would suggest you call an electrician.
    Shamokin, Pa.
    645
    Default Re: How
    Great minds think alike.
    May 2009
    Red face Re: How
    I have more than basic electrical knowledge. Have worked with electric at various jobs.
    Feb 2009
    693
    Default Re: How
    Obviously so……….. Here you go. …….. Connect black, white and green wire to dishwasher…………. That help?
    If you did not turn the power off first do not hang on to the conductor in the black wire and the conductor in either the green or white one at the same time. No, no, no!
    May 2009
    21
    Default Re: How
    A plug in dishwasher can not(and should not) share a circuit with a garbage disposer,or any other load. You need to pull a new circuit(12/2wgrd,20 amp breaker) Depending on where the dishwasher is located in relation to your electrical panel,this can range from simple to damn near impossible.At the very least i would try and get a licensed electrician to give you some guidance(expect him,or her to charge you for their knowledge)Just because something works does not make it safe.
    May 2009
    Default Re: How
    If I run a separate cicuit breaker to it will that do the trick ?
    Jan 2009
    New England
    24
    Default Re: How
    That should. It is dedicated to a single circuit which is what the code is asking. Never done electrical but if I am reading these posts right, it should cover it. Plus that is how my dishwasher is set up.
