    May 2009
    Default 3rd Floor Washing Machine Code
    I have a washing machine on my third floor. I have an automatic water detecting shut off valve at the supply with the sensor sitting in the overflow pan. The overflow pan is not connected to a drain. Does this meet code or do I need to have a drain, with a p-trap, connected to the overflow pan?
    1,904
    Default Re: 3rd Floor Washing Machine Code
    As far as I know the code doesn't address this.
    Jan 2009
    Taxachusetts
    136
    In Mass it would need a pan, however it could drain outside or into a floor drain in the cellar, or into a drain located in the area, some inspectors may ask for a trap primer if the drain is inside the building and is serving only the pan.
    Shaun
