    Apr 2015
    Default Budget for Lexington project?
    Just wondering what the budget is for the current Lexington project and if their meeting it? Thanks John I.
    Default Re: Budget for Lexington project?
    I neither know or know where you'd get that info but none of the shows I've seen were what I would consider a 'restrained' budget at all. Doing things in the best way possible as the show crew usually does is rarely cheap but is always worth it in the long run, and they do focus on that kind of quality
    Costs for a similar project elsewhere will also vary wildly; location has a large bearing on that so unless you're in that area too, so knowing the budget might not reflect much on you where you live at.
