    May 2009
    Default HELP Clogged drain
    My tub/shower drain is clogged.
    I have removed the drain plate cleaned out all hair and soap, when that did not take care of the problem I Plunged it while holding a wet rag over the overflow plate, I did this for hours.
    This morning I went to the Hardware store and bought a cable auger (the rigid power-spin). As I turned the the auger I eventually reached what I assume is the clog, the cable just began to buckle and despite my best efforts would not go any further.
    Due to my lease I cannot use liquid plumber.
    Does anyone have any suggestions, please help, I am beginning to smell and my wife is ready to kill me.
    Thanks in advance.
    Dec 2008
    Midwest
    174
    Default Re: HELP Clogged drain
    If you cant get to the P Trap with out cutting rock then I would try the liquid plumber
