    May 2009
    Default painting subflooring before carpet installation
    We are replacing the carpeting in our house. We dicovered multiple stains and a lot of dust/fine sand beneath the padding. We have scrapped the stained areas to remove the stuck padding and have vacuumed the subflooring. Is there any merit to painting the subflooring to seal it?
    Thanks,
    Less
    8,044
    Default Re: painting subflooring before carpet installation
    If you've got pet odors, or the stains were caused by pets, then yes painting the floor will help. Use a stain blocking shellac such as:
    May 2009
    Strasburg Colorado
    Smile Re: painting subflooring before carpet installation
    Yes, you should seal or paint the subfloor because if there were ever any pet acidents on that carpet then you may always smell it if you dont seal the floor I recomend a product called Kills.
    8,044
    Killz is ok, BIN is a better product and easier to use.
    May 2009
    Thank you for the replies. Although we do not have any pets, hard to say if the previous owners did. So sealing it is.
    Thnaks again,
    Less
