    May 2009
    Bourbonnais, IL 60914
    Default sump pump unable to keep up with heavy rain
    After a heavy rainfall Three inches in a few hours
    the water was coming up between the slab and walls
    the down spouts run away from the house the sump just could not keep up
    Is it possible to install an additional pump to handle the demand of a rainfall like that?
    Want to finish the basement but afraid of heavy rain like that the house is 8 years old
    Default Re: sump pump unable to keep up with heavy rain
    What size is your pump? Just knowing the pump capacity of my sump pump and how fast it drains the crock, I am guessing your pump can be replaced with a larger pump that can keep up with the water. I'll check mine in a little bit and report back with the size I hae and the line size coming out of the basement.
