    Aug 2014
    Augusta, Georgia
    Default Starting a new Living Room Project
    Planning a new project in the living room. Pull up the carpeting and replace with an Engineered Hardwood (we are on a slab). On the far wall of the room we are going to fill the entire wall with built in bookcases. What I don't know is, what order should this be done in. Do we put down the new floors and then build the bookcases, or vice-versa?
    7,243
    Default Re: Starting a new Living Room Project
    With the weight of the built in bookcase, I would install it first, then run the floor up to it, assuming you're going with a floating floor. If you are gluing the floor down, then it doesn't really matter one way or the other.
    6,767
    Ditto that.
