Results 1 to 10 of 11
Thread: Square Rooms
    Aug 2014
    Default Square Rooms
    We just recently purchased a house that was built in the 1970's. We have been doing updating/installing flooring etc and we have noticed that the rooms aren't square. My question is: Is this necessarily a bad thing or are a lot of house built out of square? Thanks in advance!
    Default Re: Square Rooms
    You will never find a home that is square, plumb, level, or anywhere near "perfect", because there is no such thing as a perfect building material or method to make them so.
    Aug 2014
    Thank you! That's just what I wanted to hear!
    I once found a house that was plumbed, leveled and square, but it was sold.
    In the morning I realized that I was dreaming.
    Aug 2014
    That is funny. :-)
    1,906
    I bought a house that was built in 1936 and has been remodeled a few times over the years. The main floor wasn't level or plumb. So I leveled it out. Now the upstairs isn't level or plumb.
    Realize that houses settle over time. This is especially true for older houses, which often were built on soft soil without bearing on more solid soil such as rock or clay. Even for those houses built on firm soil, there can still be settling. Without driving piling to solid rock, there will be settling, and that solution is more expensive than most people are willing to pay. Prior to the invention of sheet goods (plywood, OSB, sheetrock) it was common for walls to rack (turn from rectangles to parallelograms) because they lacked shear strength, unless the builder installed proper diagonal bracing.
    When remodeling, it's always best if you can first restore conditions to what they were the last time the structure was built or remodeled. That means you should probably make sure the floor is level and the walls are square before you install any new materials.
    2,743
    I once was called to look at a house which was at least 2-3" 'racked' out of plumb to help with re-plumbing it. The owner had already re-sheeted three sides with OSB when he called me, not mentioning this work until I arrived. When I told him it would all have to come off to move the framing behind it he was crestfallen, but not as much as when I quoted my price to make it right I didn't want nor did I get that job
    I've built many houses which were within 1/16" of plumb everywhere, level within 1/8" at any two corner points checked, as flat as the lumber would allow, and within 1/8" measured diagonally for squareness if the foundation was right. How long they stayed that way is beyond my control, I didn't do the foundations or footings. The perfect house will never be built because the world isn't perfect, but it's still a good goal to aim for so you can get as close as possible
    1,906
    Quote Originally Posted by Mastercarpentry View Post
    I have a saying: "If it ain't square, it's because I eyeballed it, and my eyeballs ain't square."
    I have a similar saying: "it looks great from my driveway!"
    3,201
    Framers are building houses, not cabinets.
    The house next door to me was framed in 3 days, without the use of a level or framing square by anyone on the 25 man crew. They had tape measures and speed squares. I doubt they ever heard of the Pythagorean Theorem. But hey, its just your average $800K home
