    Jul 2014
    Default Floating Floor Install - Preparation
    HI:
    I removed carpet and would like to install a 'floating' type floor. The carpet pad left staples behind. Should these be removed or can I just pound them in?
    Thanks in advance for any thoughts,
    Scott
    7,713
    Default Re: Floating Floor Install - Preparation
    You want all staples out.
    Usually, when you yank the padding, tiny pieces of foam remain with the staples. You want them out too.
    Two ways to get all staples out:
    - get on your knees and get them out one by one using small hand tools.
    - use a long handle scr-aper ($20 at floor supply outlets).
    2,623
    The scr@per gets most of them- the rest you do by hand. If one breaks off near flush, only then should you pound it down. Also check for anything protruding from the floor flatness- especially nail-heads but also splinters and lumps- as they will rub through the underlayment and cause a squeak.
    Jul 2014
    Thanks, sc****r got almost all of them. Hadn't thought to try brute force.
