Results 1 to 8 of 8
    Nov 2009
    74
    Default Adding 4-Way Switch
    I want to add a 3rd switch to control my garage lights. There are currently 2 switches, wired as I've seen in several diagrams: the 1st switch comes off the panel, then that line runs from switch #1 to the light and then finally to the last switch.
    Panel --> Switch #1 ---> Light ---> Switch #2.
    I figured I would simply swap that current 2nd switch (which is a 3-way of course) for a 4-way and then add a 3-way on at the end of that.
    Panel --> Switch #1 ---> Light ---> Switch #2 ---> Switch #3.
    The problem is that the current 2nd switch is on an old wall and I can't figure out how to fish in a new line into that wall to lead to the last switch.
    So... I'm wondering if there are other wiring options for adding that 3rd switch -without- having to fish into the wall.
    This may be a doofus question, but I'm wondering if there is a way to wire the last 3-way switch to the -light- (which is easy to fish to) and then replace that 2nd switch as I originally intended (with a 4-way)?
    Can these switches be wired in parallel and work?
    Otherwise, I guess my options are: a) tear out the plaster or b) run a really long wire from Switch #1 to Switch #3 and reverse everything.
    I dunno if I'm making sense, but any suggestions would be appreciated.
    Aug 2011
    Northern Indiana
    111
    Default Re: Adding 4-Way Switch
    Short answer is, a 4 way can be added as long as you can get a three wire cable(assuming NM on my part) from one of the 3 way switches to the desired new location. The new location will be a 3 way. The 4 way will be located at the location from which the new cable originates- the existing 3 way.
    6,062
    Because you have Panel --> Switch #1 ---> Light ---> Switch #2. the best way is to leave them as they are and add the 4 way wiring from the light to the 4 way switch. The 4 way requires 4 wires. Because of the wire count you may have to install a larger box or and additional box.
    You would end up with Panel --> Switch #1 ---> Light ---> Switch #2.
    ---> Switch #3.
    Aug 2011
    Northern Indiana
    111
    ---> Switch #3.
    If he is SURE both 3 wires go through the fixture J-box that would work, otherwise not.
    6,062
    Quote Originally Posted by brrichter View Post
    One can only go by the OP's description of the circuit.
    Aug 2011
    Northern Indiana
    111
    That is exactly what I am leery about.
    1,901
    Based on your description of the circuit, run a 4-wire cable (12/4 w/ground if 20A circuit, or 14/4 w/ground if 15A circuit) from the light fixture to the new location and put your 4 way switch at the new location (switch #3).
    In the light box there should be two "traveler" wires from switch #1 that run directly to switch #2, not connected to anything else in the light box. Take the two wires from switch #1 and connect them to two of the wires to switch #3. Connected the two other wires from switch #3 to the two traveler wires going to switch #2.
    There is no need to change connections at either existing switch.
    NOTE: 14/4 is also labeled as 14/2-2 (and 12/4 is 12/2-2). I recently saw that it is now available at my local Homely Despot. With the 14/2-2 there will be a plain white wire and a white wire with a stripe. Since neither of these white wires will be used as a neutral in this scenario, you must wrap them with either colored tape or colored marker to indicate that they are not neutral. This is a code requirement.
    6,062
    Actually to meet current code you would need 5 wire cable to the new switch. 2 travelers from sw 1, 2 travelers to switch 2, and a neutral.
