Thread: Bowed walls
    Jun 2014
    Default Bowed walls
    What are my options for a bowing wall? The deflection looks to be about 1 1/2 inches. Can this safely be fixed?
    Sep 2012
    Boston
    1,004
    Default Re: Bowed walls
    the question is what is causing them to bow. anything can safely be fixed, i think the question should be why did this happen and what has to be done to fix it. obviously we can't give you any advice without examining the situation. i would advise you to have a good contractor or engineer come over to take a look at it.
    1-1/2" is definitely enough of a bow to raise a red flag. get it checked out and let us know what's found.
    2,969
    I tell my customers that there is nothing that my skills and their money can't achieve.
    As was said, you need to bring out a keen eyed framer / contractor / engineer to determine the cause.
    I shy away from engineers as they sit at a desk too much. You need someone who actually has been in the field before.
    2,203
    I recently viewed a bowed brick foundation wall that made me run around the corner for fear of having the house land on top of me 1 1/2" is very serious, get a contractor on it ASAP and if they think immediate bracing is needed to prevent disaster get it done, then get bids and suggestions on a proper repair separately. You shouldn't need an engineer if you've got a good experienced contractor but if it's a soil settlement problem under the foundation an engineer may be in order.
