Thread: Plant Shelf
    May 2014
    Default Plant Shelf
    Hi, I need some advice for putting up a shelf across a window to hold plants. I live in a town house and only have one suitable window so a bookcase under the window doesn't hold much. The window will not allow for installing shelves inside so I have to put a bracket on either side of the window.
    I only want approximately an 8" shelf and I wouldn't be putting a lot of weight on it. I'll be putting the screws in studs.
    My window is 57-1/2" wide so I figured the shelf would be around 61-62" wide. I keep reading that 36" should be the widest to go without additional brackets. Is this true? Even if I use wood that's not prone to warping?
    If the above is impossible, would it be better to hang a shorter shelf somehow with cables from over the top window sills?
    Thanks for any help.
    Cindy
    Jul 2009
    Washington state
    195
    Default Re: Plant Shelf
    How about hanging a shelf from the ceiling? Search for 'ceiling hung shelves' at houzz.com for some ideas.
    2,194
    For normal shelving board (3/4") support every 32-36 inches is right. You could use a 1 1/2" board instead and that would work but it would be heavy and look thick. Or you could run a wire from the center of the regular shelf board upward to something secure to substitute for a bracket. Picture wire should be strong enough and would be so thin as to be almost not noticeable- and with the plants there to see nobody would be looking at the wire anyway!
    Now if you can tell me why my snap-dragons haven't come up I'll call it even
