    May 2014
    Default Where to buy Terra Cotta Foundation Blocks
    We have a house built in 1920 that has a Terra Cotta Block foundation. Does anyone know where we can purchase replacement blocks to replace ones? The Terra Cotta blocks are 4" x 8" x 12 " with two holes going through the blocks on the long dimension. Thank you.
    1,517
    Default Re: Where to buy Terra Cotta Foundation Blocks
    1,131
    Partition tile is non-load bearing class, and not for foundations!
    wiki:
    http://en.wikipedia.org/wiki/Structural_clay_tile
    you need what's classified as ASTM standard C34, LBX for load-bearing in exposed location.
    found one supplier for you (in Canada) http://www.paisleybrick.com/spec1.pdf
    1,517
    You're right the tiles are not exterior use, but they appear to be structural. I can't say I've used them or any other structural clay tile before.
    You just can't go down to HD and pick up a few when you need them.
    Calling Sandkuhl might get some suggestions. I've found companies are often knowledgable and willing to help when their product won't fit the bill.
