    Jul 2008
    17
    Default can i just fill these holes with foam?
    our 20 foot patio has a metal roof.
    where it joins the house are a row of 3" by 3" "holes".
    can i just fill them with foam or something.
    the wasps love to build nests there.
    thanks all
    ps why does the manage attachments not work?
    it says it is not a valid image file
    i posted pic before
    see the pics at http://www.diychatroom.com/f9/wasps-201215/#post1354502
    7,583
    Default Re: can i just fill these holes with foam?
    You can use bondo to fill the holes. Wasps can chew the foam.
    Jul 2008
    17
    thanks for the surprising idea!
    3,167
    Might wanna use foam as a backer / filler then bondo the surface
    Jun 2014
    6
    I think filling holes with foam can be a very bad step.Foam tend to disintegrate very early.So you should search for a better option.
    3,167
    foam disintegrates when exposed to sunlight but it still takes years. The bondo will shield it from the light/
