Results 1 to 7 of 7
    May 2014
    Default Horizontal stud finder
    I saw on an AskToH show, a Horizontal stud finder. I'm looking for a retailer that carries the finder. none of my local retailers carry or even heard of the finder I'm looking for.
    Description of Stud finder: 7 -10 inch wide and 2+ inches tall, yellow plastic tool. there is a flat handle in the center of the bar. Along the top third of bar there are 8 to 12 red LED light bulbs in a row. These lights will light up when over a stud ( no more than three at any time ). the finder has a black backing pad as to not scuff the drywall when in use.
    I really would like to find this great tool, and add one to my collection.
    I have found what I am looking for, Thank you all
    Sep 2012
    Boston
    1,004
    Default Re: Horizontal stud finder
    is this the one you're referring to?
    http://www.sears.com/franklin-prosen...6&blockType=G6
    6,966
    Because horizontal studs are harder to find than vertical studs? An electronic stud finder doesn't care what orientation a stud is inside a wall, it senses wall density. Hold it vertically to find vertical studs, horizontally to find horizontal studs, lay it flat to a ceiling to find ceiling joists. Don't even bother with the magnetic type, they are worthless because your target are the metal fasteners in the stud, rather than the stud itself.
    Google "stud finder" and you'll find what you need.
    May 2014
    Quote Originally Posted by MLB Construction View Post
    Yes this is exadtly what i am looking for, Thank you.
    Sep 2012
    Boston
    1,004
    spruce, i know the one he's talking about. for vertical studs you hold it horizontally and the lights show you each side of the stud. look at the link i attached in the earlier post.
    6,966
    I tried, Sears doesn't like my computer settings.
    Apr 2014
    Louisiana
    29
    Holy cow I just looked it up, neat product but 83.00 for a studfinder!?!?!
