    Mar 2013
    24
    Default branching vs chaining outlets
    I need to run 3 outlets in my unfinished basement, I will tap into an existing line with only one outlet on it and run towards my intended direction. The layout plan is in the form of a "T" so it will be more practical to BRANCH rather than CHAIN the outlets. Is it acceptable to run the power wire to a junction box and pigtail all the wires (4 wire pigtail) and than run the 3 branch lines out from there?
    thanks for the help
    7,762
    Default Re: branching vs chaining outlets
    As long as your j box is not concealed - you are fine.
    Dec 2012
    New London County, CT
    124
    And the number of wires in the T junction box does not exceed the allowable amount for that size box.
    Mar 2013
    24
    i will be using 4" squares 2.25" deep
    are those ok? what would be considered overload?
