    May 2014
    Dayton, Ohio
    Default Lead Paint Removal from furniture
    Hello,
    First, let me say thank you in advance if you are viewing this. I am in a bit of a dilemma. Recently my wife noticed an interesting piece that looked like an old mini bar. Upon further inspection it turn out to be two separate halves, one being a head board and another being the foot board. The piece itself is solid but most of the flourish and finish is falling off. We decided that we could re-purpose them into a hinged mini bar since most of the finishing details have fallen off and the rest are beyond repair and fall to dust if you look at them funny.
    The piece itself is painted and cracking and chipping pretty badly. I thought with the piece looking fairly old it may be best to test for lead and unfortunately it appears that there are slight traces of lead present. Before I give up on this and contact my city for disposal purposes, I would like to find out a bit more about possibly removing the paint and trying to re-purpose it.
    Since the paint is cracking and chipping pretty badly I believe (based on some minor research) that encapsulation and encasement are not an option. Does anyone know of a safe stripper to use that is economical and environmentally friendly to remove the lead based paint? Citristrip appeared on TOH post I found earlier. It appears there only 2 layers of paint on the piece itself. There may be a varnish behind that as well. This would be a project that I would complete outdoors (where the piece is due to my suspicion, it was not coming into my home).
    My other concern is that once the paint is stripped it may require light sanding before repainting. Is this safe? can the lead leach into the wood itself? I just can't bring myself to pay someone $150 to $200 to remove the paint on a piece that is a rescue/recycle project.
    Any advice and help is greatly appreciated. I can post pictures once I upload them from my phone.
    Thanks
    Jmercier76
    Jun 2009
    401
    Default Re: Lead Paint Removal from furniture
    You could look at this product Leadout paint stripper.
    EPA approved cost about $ 100.00 per gal.
    May 2014
    Dayton, Ohio
    Thanks, I did look at that product and considered it but it doesn't seem to be available locally and would have to wait for shipping. I understand how hazardous Lead can be, but I would have hoped more stores would carry a product like this :s One of the local hardware stores recommended Citristrip but the product does not say anything about being used with lead.
    Should I be concerned with sanding the piece after using the stripper? I did see that one of the big stores carriers masks that have lead filter cartridges.
